Can't wait to see what you do to it.
I can't wait till the project looks like it's namesake.
Anyone know of any led alarm clocks that have seconds on it. All I can find that has seconds is something in the $200 dollar range. There are...
Thanks for the idea, after a good nights rest you got me thinking. I figured out how to do the motor problem. I don't, I use a laptop drive and a...
Not quite, something like hydro_electric_655's post. Gamecube is very close to the idea I have but no top or popups. The finished top of the...
In a sort of "Johnny 5" sort of way No repair, modify. I want to make a top load cdrom I have an idea how to make the rest of the mechanics...
Does anyone know if a motor from a portible cd player can work in a cd rom drive? Such as the motor that spins the cd?
I tryed their site it seems to be down
Prefer every event but will gladly accept one edge pulse Long enough to turn on a computer
I've searched for a circuit that will turn a constant on switch into a momentary switch. I've checked google and all I find are the oppsit of...
Dang you want me to reveal my "Master Plan(TM)" . I love the case as is but needs some help first AT -> ATX conversion. Plus afew other ideas that...
It's only a setback, not death of this project. My next stage is to hack up the back to fit an atx backplate. With the holes on the motherboard...
I bought an AT case about 4 years ago with a free motherboard (dead 386). So naturaly I removed the mobo with standoffs attached because I'm not...
DAMN! When you can you gotta build a monitor(LCD) to go with it.
I don't know if anyone said anything about this but you could use the hard drive as a activity "light". It takes some hacking of the controller...
Would a relay work just as well or is there a "absolute must use" reason for an optocopler/opto-islolator?
How would this be done for a desktop cdrom drive far as getting a spindle that holds the disk in the drive. I have an idea for the tray that gets...
On another post I made I found that mineral oil will work with electronics but how do I clean the boards of the oil?
How would I clean parts that need/want to be pulled with mineral oil all over it?
