Window Etch, they're not too difficult. I haven't done it myself yet, but I intend to. Draw the design with a marker onto the Acrylic, then...
Within the UK would be great, I'm looking for "Software Programmable LCD Modules", just like the ones on Crystal Fontz. For example, I like the...
Thank you, I see, because the 12V from the yellow wire (eg, Floppy Power Connector) isn't enough, the invertor increases the voltage to 400-800V...
And then 105 Piece Rotary Tool Accessory Set from the same place :rock: Or, from Argos: Challenge Xtreme 130 Watt Rotary Tool Kit £29,99...
Nice etching, I haven't read all the posts because I'm drawn to the pictures :rolleyes: I'm guessing you're using a Dremel to etch that design,...
Those boxes connected to the "Cold Cathode Flourescent Lamps" (yeah, I looked up what CCFL means). Are those boxes the invertors..? (because...
Nice, When you get time it's just a case of matching all of the metal to the same colour (unless it's gonna' be spray painted) :) and it'll look...
Prescott CPU's are famous for their heat problems, Intel are still working on this problem and are predicting that it'll be sorted out by the time...
I've gotta' say that the ideas on this forum (and thread) amazes me. I haven't seen half of these things before, and some are so simple: - LED in...
Brilliant PSU mod - I haven't seen that one before and it gives me ideas for my first mod (still in the thinking process). Oh, can we see some...
I thought 3mm was too thin. 8-10mm would be the more ideal depth for a case. The 3mm can be used for things like logos (and prototyping). I...
I had no idea, I thought they all had completely different properties and purposes. As long as I got the numbers correct, and the theory behind...
Thanks, I've added that site into my favourites (any more links would be great). Just gotta' figure out the meanings of all these numbers:...
n00b question. How do you get to display whatever you want. Does the software/drivers that comes with it have an input GUI that then saves the...
I'm looking to buy Acrylic sheets to create my own mods or even build my own case completely from scratch (what a challenge ey :rock: ), and still...
Nice, but two comments: 1.) Fans on the top/back - just for appearance or do they have another function I'm not too sure about? 2.) Why are...
Can't see the pictures :worried: Maybe your bandwidth allowance is exceeded, or something to that effect?
Here's the thread with the full information, entitled "How To: Make a cheap molex pin remover":...
Thanks khendar, it's a long process indeed. In that case, I'll find other solutions and use chrome if absolutely necessary to mimic a shiny metal...
I see, because I was thinking it was a little dangerous for household users. I'll have to do research into chroming areas around my area now....
