uhm..hes using a epia psu, wheres the problem adding a fan?
uhm.. the via epia processor doenst get very hot..you could use the place where the cooling should be for a psu . the psu fan could cool both.....
yeah, it still opens like a regular briefcase ive just removed 1 side, to get my mobo tray in. and drilled/cutted on the other side 2 big holes...
hes talking like master yoda :D
use different resistors on every led.. stronger on the outside and to the middle let them get weaker...
quote : "Before anyone asks where the window, cold cathodes, LED fans etc are........IT DOESNT HAVE TO LOOK LIKE A FOOKIN CHRISTMAS TREE TO BE A...
maybe...the help file? :naughty: there are tons of other commands.. and the layout? just change the order of the commands.....
uhm... self written osd script for motherboard monitor <text color=$00000000>CPU: <CPU 1 Speed> <text shadow=off>:<Temp 2 Value> <br><text...
yeah..lol but with shipping and stuff it was a lil bit more
yup, but it switches automaticly to main screen mode without monitor connected,so i can use it as mp3 server, or dedicated gameserver.. tv...
ive tested it with a hammer... no problem here... and the system is absolutly closed, the pump is able to work in horizontal and vertical...
nope.. its connected inside of the puter with the dvi connector on my radeon
because the radiator of the watercoolingsystem is behind it. i want to get the heat --------------->oooout-----------> of my system,thats why it...
ok, thx :p
a toshiba 5" tft i hate geocities :D transfervolume is expired already..
a status tft :naughty: the only thing thats missing now is some stuff to cover the cuts on that thing..rubber trims or something like that.....
:D
nm
ok..here its pratically a mobo rack inside the case [IMG] ive optimized this setup to my needs, im not offended by powercables or other...
yeah, thx, ive dropped a line in the lcd forum, i hope hes still around. thank you again.. :eyebrow: next time im going to buy a original...
