I probably should consider AMD, but I'd just prefer to stick with Intel, no real rational explanation :) Turning the question around slightly, if...
Yeah something like that is what I had in mind, keeping the storage/case/PSU. I keep looking back at Haswell-E as I'm considering VM's and...
Not been on here in ages! I've been mostly using a laptop/consoles for the last 4-5 years, so I've been neglecting my desktop systems, which are...
Not locally or got any other PCs that are capable of running it (all mini-itx/htpc). I'm tempted to get a new PSU just in case (as it'll probably...
Sorry, should have said. Yep, swap that back in and it's fine. I noticed a thread from a few weeks ago about Scan shipping refurbs, but it looks...
I've had a system for a while now which is showing its age (no OC, Q6600, 4GB DDR2, Gigabyte P35-DS4 mobo, but with a 6950 PowerColour card) and a...
There's a shop near me doing 500GB for £32. Quite lucky at the moment! (Not a computer focused shop, so probably hasn't noticed the price increases)
Unfortunately it *needs* to be low-profile due to the case. That afox looks good, but I suspect it'll be like the sapphire and as easy to find as...
I'm looking at putting a decent low-profile graphics card in my HTPC which is doubling as my main machine atm. I've got two 24" monitors...
It depends. When I got mine (Kindle keyboard + 3G) I headed to America for a week or two. Having worldwide free access to wikitravel/wikipedia and...
I'm looking for a new laptop to replace my broken Dell XPS M1330, but I can't see: to find anything comparable. i'd just go for the same one...
Hi, I have a fileserver that I want to play stuff off via a network share, on my TV. There's loads of things out like...
Hi all, I'm after a new laptop, after having been given some money (£900) to get a new laptop. Need it for uni, so portability and long battery...
Hmm, perhaps. I fitted it outside of the case - depending on your case, it will be impossible to fit in the case. Also, My case has a removable...
It was difficult, not impossible though. One in particular is a right pain. Took some pics for you: Overview (look at top right): [IMG] The...
I really wouldn't recommmend getting the DS4 and try the Scythe Ninja cooler, or any large cooler. the massive heatsinks make it *very* hard to...
Is it *that* good? *looks at spiralling upgrade cost* :worried: wait wait "What makes this case so different from the 900 is the fact...
My WaveMaster is showing its age, its beginning to fall apart and its VERY cramped, so I'm looking for something a bit better. Needs to fit 4/5...
Not sure if it applies to the 16xxx series (only used 18f..) but have you got *all* power/ground pins on the PIC wired up? Or, unlikely, but...
cosmic: is that cooler you're getting a rev.b? scan doesn't state it as such explicitly...
