I'm pretty sure this EK block is the one I'm after.. But finding one for sale is proving a challenge, lol. EK-FC670 GTX DCII - Nickel...
Balls, I thought you might say that. Mine has ASUS stamped on the board by the PCI-e connector. So by what you're saying, this is a custom Asus...
Hi all, Is there any easy way to tell if my nVidia GTX670 is of nVidia refernce design or not? I'm after a block for it, but as there doesnt...
Thanks Goatee, appreciate the input. I figured 3m would be enough too (especially as its a very small loop in a normal sized case), but just...
Hi, I've been out of the loop for a while (hah, loop, get it? nevermind). And I have a hankering for sorting out a water cooling setup for my rig....
My current cooler is the arctic cooling freezer 7 pro. It's ok. Could be better. Lol. Hoping my 680i SLi supports the e8500.. Any reasons why it...
Aaah the wonderful e8500, first range of 45nm chips weren't they? I remember them being praised when they came out. £50 on eBay, not bad....
Blogins - PSU is a Coolermaster M600 Silent Pro. I'd assume it's fine for running two 8800's, but I think I'd rather run the GTX than have 2...
Thanks for all the replies guys :) Appreciated Yeh the CPU I was going to try and get something like the Q6600 or even one of the quad extremes...
Honestly I don't have a budget for this, lol.. What card is available out theire to replace my 8800 that costs around £30 then? I didnt think I'd...
Evening guys and girls. Quick one for you all as I'm a little out of the loop these days. About 3.5 years ago I built my main rig that I'm...
two switches i wasnt aware a 4017 could be used to to only cycle when a trigger is pushed by analogue, what do you mean, sorry, at the moment...
Yeeeh, i'll simplify it a bit, i've got a project going, the item i've got has 4 modes, selectable via a 2 pole dip-switch, meaning possible...
I'd been looking for a while prior to asking on here, the main DAC you can either scrounge samples for from cirrus or farnell sell them farnell...
Hey ch242, thanks for the reply, yeh i saw that project in my endless searching, that seems to be the easiest way, i've already started drawing...
55 views, no replies, wheres everyone like cpemma when you need them??? haha pleeease help!! :)
Hey all you electronics gurus, need a hand on where to start with this one. I have a non-dolby-DTS 5.1 optical signal coming into an amp that...
