I Love Aquatuning and Bit-tech so much It makes me turn GREEN! :lol:
I don't condone his actions he crossed the line after accessing the phones he found after the port scan. The first thing i did was override the...
its loosely based on psychological studies "even if the product is pants it sells better with an i in front of it!" only joking ;)
A number of people are using prifinitty, you may want to give that a go. There is a guide provided by phoenicis here.
Once its on a single pcb you will be able to water cool it with a single slot waterblock similar to the one for the GTX 260
Supposing you had the cash and a large enough power supply you could effectively run 7 GTX 295's on the P6T7 mobo!
Haha i love the fact that im not the only one that gets stick from the missus. I think she is coming around now though, plus like you say get the...
right click on your start up folder in the start menu and click 'open' try drag and drop the shortcut into that window.
i would leave a shortcut off the exe or batch file in the startup folder in the start menu
Do you know why the mb and cpu died?
Has anyone here built a rig with a similar spec?
It annoys me in general when announcements like this are made at conventions. I want to hear hyped up statements when the initial ground work has...
The shape size and color will change but we will still put our home PC components inside a box.
Unless its leaked they prob wont release the details officially until the last minute to keep the i7 orders coming in. I'm happy to wait for the...
I guess it would also depend on the maximum production of a single unit compared to spreading your budget across a number of machines. It would be...
Tell me about it i was 70% through a 1920 pointer this morning and got an "Client-core communications error: ERROR 0x1" Gutted!! I think it was...
I enjoyed reading the latest Folding@Home article in CPC issue 70 and you managed to convince me to join in on a more permanent basis. I...
I think it would be nicer to have the attention stay on the forums everything is recorded and can be reviewed back for others with the same...
I think it would be nice to see an alternative graphics card for the folders amongst us.
“Look behind you! A three-headed monkey!” Perfect, such fond memories. Was a little gutted at the time when my pc wouldn’t play Escape from Monkey...
