Just got an Amazon Fire 10.1 HD tablet for just home use. Lovely screen and all that but it does not support Adobe Flash Player ! I read on the...
https://www.tritonshowers.co.uk/shower-types-explained
https://cazana.com/uk/car/VE66ZDL
I used to be a werewolf. But im all right nawwwwwwooooooooooooooo
So how did you sort it?
http://www.kkmoon.com https://www.google.co.uk/search?client=opera&q=02392695968&sourceid=opera&ie=UTF-8&oe=UTF-8 Might be worth phoning...
Im typing this on the affected Linx. All sorted and working as new. It did indeed turn out to be a DHCP issue. Edge, IE, Opera now work fine. Now...
I have a 'LinxL ight 10' I got from Sainsburys 13 months ago (out of warranty) Windows 10 was "upgraded" to 1607 version by Microsoft. Since...
might be a good idea to inform your insurers about the change. things might get a bit tricky if you should have an accident
The problem might (might) be with your motherboard driver for your usb3. I had to reinstall my usb3 drive on two gigabyte motherboards. All...
http://i914.photobucket.com/albums/ac345/wufer_album/private/Capture_zpsmlwcf0gi.png 206 failed Mmm, still not fixed:wallbash: Tried...
Well well, I just had the same problem yesterday. New install Windows 7, on a new ssd. Installed ok. When i clicked for updates page, there...
Not sure on the "legal" side of things, but i get 'all' my windows second hand off e-bay. Ive had no bother activating them, and i have just...
Update. Just checked all my machine, and there all working fine now
Kronos. Im with Plusnet too. One of my laptops, and my desktop are acting up just like yours. But this laptop im on now is acting normally.
No offence taken:D. A wise old Chinaman once told me. "There are no stupid questions...only stupid answers" Ha so:D
Cheers No driver , well that shows how much i know:sigh: Windows7 should run ok on a Turion. A friend has the same set up , and as a family...
I have a Dell Latitude 131L, with a 'Mobile AMD Sampron 3500+' cpu. I want to replace the Sempron with a 'AMD Turion 64 x2 TL-50' CPU. I...
This seems to be the problem. This is from HDclone free. "The Free Edition of HDClone, clones an entire hard disk to another larger medium" So...
I just got a Dell Latitude 131L laptop off xbay. It has a SATA 60gb hdd... and windows 7. I was hoping to fit a sata ll or sata lll SSD ....
