How long did you leave memtest running? Even if your memory is indeed somewhat defective, it might not show any errors during the first few runs....
Resets under stress for no obvious reasons usually point to power problems, yes. Try to get a PSU from a friend or something to replace your old...
That depends on what you define as "decent" though. If you need over, say, 4 hours, it's very hard to get that on a cheap 15" notebook.
What Cupboard said, if you're planning on using it for uni projects etc, a CULV -bases laptop would be ideal as you'll have a screen on which you...
If you don't need the upgrade, don't do it. I mean, do you have problems running any of the programs you need? If not, why upgrade? Unless you're...
Sorry to dig this up after 3 months, but I hope you got the CULV laptop (I love them :p) since it would be so much better for your needs.
To put it a bit simpler: your wireless network speed is WAY faster than your internet connection speed, even with the 802.11g adapter. Nothing to...
Yeah that's definitely a screwed up MBR :( Good luck though.
Does this help? http://support.microsoft.com/kb/919529/
Yeah but the MBR (Master Boot Record) will still be on the old drive meaning that when it's removed, the BIOS won't find any boot loader to taker...
Dell laptops are know to be pretty reliable too, they're always one of my choices when someone asks for laptop advice.
Have you tried eBay? With a quick search I found this, for example: USED DELL 3300MP PROJECTOR DLP LCD HDTV PARTS REPAIR
Maybe you overdid it with the SEO and got some sort of penalty from Google, I've heard that happen before.
Exactly. The simplest solution is to reinstall Windows 7 without the old drive attached, this way a boot sector will be created on the new drive.
No, that actually makes perfect sense to me. I never invert the mouse on PC games though, ever.
I've been playing FPS games for almost 10 years and I always hated it. Using it with an operating system is ok, but in games you can never be as...
Not to dishearten you, but if it's a hardware problem, any-level-formatting won't really help. I don't really trust SMART though, I've had an...
That's the way I usually do it. The pressure from the heatsink should distribute the TIM evenly. I think that some people manually fill the whole...
Being a fan of progressive partial upgrading, I'd say the last option. Although considering the rate at which Intel changes sockets, you never...
