https://www.youtube.com/watch?v=dU7iKNmQBIs
http://www.youtube.com/watch?t=64&v=P3WnQ246f1g
I think you might consider put your hdd's on horizontal or vertical position. I did the same thing on my project (45 degrees angle) and one disk...
Hello everyone from Greece! I 've been working on a new project for a few months now and since I 've made quite a progress, I think it 's...
just epic!
Attila i think ''Cor Leonis'' is the best project i have ever seen...keep up the fantastic job!
Very nice!!! I think you should put a carbon sheet between the ssd and the heatpipes, in order to prevent ssd overheat.
I have this and it works. http://www.mitxpc.com/proddetail.asp?prod=APCIEX16FR&cat=184
Very very good!!! What kind of plastic did you use?
http://www.youtube.com/watch?v=aE3R1BQrYCw&feature=player_embedded
Excellent work so far, sweet colors, and fantastic photos! I think its going to be the next ''million dollar pc''.... Καλή συνέχεια!
I think it will work fine.
Something important: When you post the temp results, tell as and the ambient temp.
Excellent so far! I 'm waiting for your temps too, in vertical and horizontal position. Question: What is this hole for? [IMG] I think...
I have to say that i have doubts about the final result. I think that the heatshink wiil work better in horizontal position than in vertical.
I agree, but copper transfers heat quicker than aluminium to the heatpipes. That 's why it's used by manufactures at the blocks. Also copper can...
Very nice work so far! Why didn't you use copper for the blocks?
YuD10VqNo2Y juwr0F45ql0
Remember me? (guess not...) I started a few months ago this worklog in order to show you my work, but as it seems it didn't go as good as i...
http://www.youtube.com/watch?v=rQFpS_tDD9c&feature=player_embedded
