I have emery cloth which is fabric with some gritty stuff on one side - it's around 1500 grit if you were to classify it - it's really used for...
Yes. I work at an ISP and that's what we recommend. It doesn't screw up your computer as much and detects virii much better. moorecomp -...
Oh, goodie... That should give you directions for making an h-bomb. But, it was a joke so nevermind. :rock:
Did I mention most nasties that live in pipes won't survive nuclear winter? :D Go here to see how. Note: I am kidding...
Yes, believe it or not, the anti-static bags hold all the pins at the same potential. Talked to an electronic circuit designer, he said they used...
To clean the nasties out of mine, I took a piece of a paper towel, wadded it into a small ball that fit through the tubes, then shot it through...
Should work.
Should be able to.
Yeah, I noticed that. It'll take a bit of code to fix that. If you're going to work on it, I won't.
I use bottled water (one drink for me, one for the system - but seriously it's demineralised) along with antifreeze plus a splash of windscreen...
C++ or not, this code will work and will be faster and cheaper. Evil the Cat, it looks good for a beginner, but remember to keep it simple and...
Yeah... but as a spool... If you buy some and they ask why, tell them you're making a heater.
Maybe the mods could delete some of the spam. But then, lorquis wouldn't have any posts... :D
Couple bucks... not much; I only got a 10 foot spool, it's hard to find.
Look for nichrome wire. I went to the local junk shop, bought a spool, apply 12VDC, 120VAC, anything, POOF. It'll light a fuse. I use it to...
I dunno, that King looks pretty evil. Not at all like G-Gnome. :hip:
I agree - I have WCed dual Xeons plus an ATi 9700 and my water only comes out a little warmer than what it goes in.
It's rather amazing he's not injured .. or is he? :eyebrow:
Shocker pens. Fun fun fun. I got nailed with one and jumped. So, I borrowed it at got some teachers at my high school. Most took it well.......
I know, I'm just kidding.
