I had a solder-iron holder that wasn't designed for my iron. I didn't notice that the tip/shaft was leaning against the heat guard and metal...
Ah the memories, where should I start. 1. When I was real young I was watching my dad chop wood, so I took a claw hammer and was using the claw...
Sry for the revival, just thought I'd share... Afetr I had figured out the pin out on the Torisan display (much poking and proding) and what...
I know I'm just reitterating, but some of this is new. Going to be very tricky due to increased latencies caused by the increase trace length...
Make sure you heat everything you're soldering together at the same time, otherwise you could end up with a cold joint that looks fine but isn't.
Not saying the others aren't bad, just saying that I use a 10mil (.010") tip on my weller and have never had any difficulties soldering 0604 smt...
Most of the colleges I know don't offer summer electronic classes, only programming ones. The more I think about it, I don't know of any colleges...
Griffin makes an item called a powermate. It's a sexy alluminum knob that is underlit w/ blue led's. It's a USB device and software programable...
I typed this once but lost it because of a timeout request, so I'll just give you the short of it. The whole field is fairly diverse, so you...
I personally prefer Weller's. I've have a WTCPT for several years and love it. I don't know if they have ones with a temp dial but my tip's temp...
Maybe I wasn't very clear on expressing what I was hoping for. I know what the 20-pin connector (even though there is no physical connector, it's...
So first off, I have :search:, and read, and thought, and google, and :search: some more, and here's where I'm left... I have removed 2...
http://www.tapplastics.com Good for acryllics/plexiglass and related materials
https://www.barebonespcb.com/ Decent cheap pcb mfg
Ooh, here's an idea, how about powering your mobo with a couple high current inverters, that should pop some caps.
I personally have never worked with Lexan, but there are a couple things you shuld know. Lexan and Plexiglass are just name brands. Plexiglass...
