Is anyone else annoyed by all the bright LEDs on their electronics when they try to sleep? In my room I have multiple devices that have the...
So I haven't been keeping up with advances in CPU for a while. Last time I remember AMD had 333 FSB and Intel had 800 FSB. Can someone tell me...
I was trying to open it in iTunes. :worried: I didn't know mms was a windows format. Any way to play it through iTunes?
Hi. Well I am trying to play a radio station, but it won't work on my mac. Can someone extract the stream from this url? I tried playing...
is it possible to add user from my WORKGROUP to my folder permissions? Thanks guys
Ok... so i'm trying to create a file server in winXP. Here is what i want to do. -I want it setup so everyone on my network can view the file,...
Well, I tried to take the LCD off but i stripped one of the screws off because i didn't have the proper size screwdriver. So i'm going to have to...
That's why i'm buying an iMac this Christmas. I know, i know.... it sucks for games, but since i hardly play anymore (except for important stuff...
Thanks... i hope that's the problem... i will open it later today and let you know how it goes!
I hope it's not cracked... if it was i don't think i would be able to bend the lcd and make the line dissappear. how much did it your friend have...
Well I dropped my laptop a couple times and now sometimes i get this blue line down the middle of my screen. The weird thing is if I twist my...
thank you very much.... i will look over the page again and try to figure it out. thanks for help!
Thank you for your repley. However, i have no experience with batch files and i can't seem to make sense of anything. I would greatly appreciate...
Hi guys, Well, here is what i want to do. Problem is i don't know how to do it. I want to create a simple program that will Extract all my...
Thanks guys!... i'm going to buy it off ebay then
Thanks, but i live in the US (California!). EBAY USA doesn't have those auctions Actually i have space on my motherboard, but i don't want to...
I have a Shuttle MN31N and it has it for sure! However, they were cheap and didn't want to include it with the motherboard
I'm not sure if this is the correct name, but does anyone know where i can get one of these? It didn't come with my motherboard :waah: [IMG]...
[IMG] That's an apple mouse? I didn't think they ever made a two button mouse :confused: Also is there a scroll wheel on it??? :confused:
Thanks a lot for your help guys... at this point i am thinking it has to be some sort of bug w/ the mobo and xp. I'll try contacting tech support...
