Saw this little bit of info, hope it's of some help to point you in the right direction. link
That's coool. I like it when the led's chase around the edge :thumb:
Thanks for the answers! Just had our electricity redone after a flood and the guy fitted an rcd and put a really meaty earth cable to a rod...
I get it so far... But what's the difference in earth and neutral then? (For uk spec)..
That's a good explination! I was one of the people who thought they switched polarity and always wondered why only live was switched :duh:
You could use some thermal epoxy. Kustompcs in Ayr does some Arctic Silver Adhesive for £6.50 though you may be able to find something cheaper online.
There is an example of how a 2d led matrix works here I'm not that good at electronics, but using the example and an extra 74164 shift...
Don't have the orig pics on the webspace anymore, I'll try and find them.
I'd forgotton all about this mod! Good that you fixed it eh :thumb:
Another vote for ATI. I've got a Radeon 9000 (PCI!!). I used radeontweaker to turn on the overscan and ***bang*** bye bye black borders, hello...
I bought some NMB 18cfm/15db for 5.29 each from Panaflofan - I've 2 of these on my dual xp1600+ cpu's and two in my 550Psu running 24 hours a day...
Congrats Darkside, I suspect you'll be doing more late night posting when the whole house is awake!
mikaelgu - I'll try UICE, like the typing idea with the remote! Just been having a look at the website and it supports my Packard Bell card... :D...
JazzXP - The CF card was the best move I made. I picked up a CF adapter from linitx.com which makes the CF card act like an IDE drive. The main...
whypick1 - Thanks for the info, I'll have a look at the Samsung drive. I read quite a few reviews on the aopen one, but it just didn't to the job....
lucifer - running windows 98 (lite) with dvd, divx and xvid playback. Tried movix and linux and even xp cut down (only got it down to 400mb)....
Cheers guys. It took me ages to find the case. Its an AOPEN A340A and I think you can get them from Dabs in the UK. The PSU is V QUIET and the...
I've had this htpc thats taken loads of money and loads of time to put together. But I had a big problem. 5.1 speakers and no 5.1 sound card that...
Ahh just reread the thread where you said the front would be plexi and you would paint it. Are you going to paint the back of the plexi...
Like the colour! What are you gonna do with the front of the case? Plexi?
