Never had a problem when I returned mine. It had a couple of issues with pixels when I got it last year, swapped it for a replacement easily...
This is largely my view as well. Was tempted by the free upgrade and especially DX12 for gaming, but the privacy issue, real or otherwise, is a...
So DX12 is likely to overtake DX11 in the next year, but by how much? If a game is developed on DX12 only it cannot be played on Win7 (DX11) I...
Any major difference between dx12 to dx11? What I've seen so far pretty even, will this also be the cse in 12 months? I'm still on win 7, so will...
What's the current state of Vulkan and when might wider adoption, if at all, happen with respect to games and GPUs? Trying to decide on a GPU...
From my own experience, I tend to prefer MSI due to larger fans, slower rpm and quieter cooling. But the MSI gaming versions from both AMD and...
Okay, with that in mind, what GPU to consider for the next 2 years? Currently have i5-4440, 8GB ram and 1080p/60fps monitor. So am I right in...
Is it true that Nvidia GPU's don't receive proper support beyond 2 years and are AMD better in this regard? With that in mind, is 2 years after...
Typically GPU's get released every 2 years, not always, but mostly from what I've seen and read. Those of you who are long time GPU owners, when...
Agree with the above poster. Sadly, I can't see it changing any time soon. It's no coincidence that Nvidia cards tend to be the main culprits in...
Mine as well.
Will the tipex cause any issues with any components, esp the motheboard?
Currently have a MSI GTX 970 for 1080p 60fps gaming, in high/v high/ultra, obviously depending on the game. Seen the releases of this years...
Hi all, I have a Fractal R5 white case and there is a small part inside the case that will be visible throught the window where the white paint...
Looking for a surge protector for use for a typical pc gaming setup. Live in the UK so it slightly affects some choices, but all recommendations...
I got my LG G4 from ebuyer sim free for a decent price, could give them a look.
I'm glad to see this happen and you guys to go out of your way to make amends for the un-intended mistake. It was also right not to remove the...
I didn't notice that, good catch. It is a shame, especially as it took so long for the winners to be deicded. Maybe futur competitions will be run...
I do like the look of these.
40mm. Thank you.
