Not sure if it's the host or the file size of the graphics but it seems to take a long time for me to load upon first page view. The blue kinda...
The problem is that the fstream cannot take a string but instead a char string (atleast on the version i'm using). Try fstream...
I disagree about remote desktop. I feel it's too slow to respond, it's clunky, and it causes the current user to have to log off. Half the time I...
Only thing I can think of currently is a version of ipchains for windows (GUI'fied and made windows n00b stlye like everything else would be ok)...
I honestly have used them both and have no problem with either. I like the database access in ASP much better than the PHP way but now that i've...
This is actually for more of an mp3 player idea (not exactly but I really can't discuss many details about it). I need to be able to read mp3...
For a current project i'm working on I need the use of USB on a chip without the use of a PC. Reading some of microchips website/forum I've...
I have a chained hash table filled with an object (string, int) and need to pick out the 5 objects from the table with the highest int. Now, the...
As far as I can remember (which usually is pretty good) IIS doesn't have any sort of built in mail daemon and that is where Exchange server comes...
How much would you be willing to sell one of the blue ones for fully assembled and shipped (or would you be willing to at all?)? I really like the...
Do an ipconfig and look to see what the gateway is set as. It should be 192.168.1.1 if it's been reset. If it hasn't been properly reset, while...
You should also attempt to fully read and understand the post. I have one that writes and verifies but without knowing that the code is 100%...
I was just wondering if a PIC would still program and verify if it had been fried. I'm afraid I might have fried the two PIC's I bought but i'm...
Flawed argument here. The Nazi's didn't send killers to death camps (well, some maybe, but's that's hard to tell) they sent innocent human beings...
The reason I chose to go WinIO is because people have had success using it. Speedfan uses giveio which is virtually the same thing as winio which...
Yeah, i've had speedfan installed for the last few days and i've been trying to figure out what those values are. From what I gather, first you...
I'm using windows xp. With WinIO it takes care of allowing you to access the specific registers. The problem is i'm not sure what registers I need...
I need the help of a prety good programmer. I'm trying to write a program to read the register that contains the speed at which a fan is running....
nm, i'm an idiot.
Any suggestion on what I should get to transfer this whole thing to a proper protoboard?
