Can YOU Machine This Reservoir? Trick Question... its a plug not a reservoir or distribution plate since it only has one port.
This mouse does have its flaws. The extra right click and left click buttons are a great idea, but due to the shape of the mouse (a narrow front...
I dont know about those motherboard mentions... I would have noted the Asus Rampage III Formula and Rampage 3 Gene (performance and mATX). The...
I dont know a
@solanx, The shell of the Rude Fierce is one that Mionix (its actually the same mold as the Saiph 3200), Steelseries, Qpad, etc... have all used....
Seriously, your mouse reviews suck bit-tech. I decided to spend the money and have purchased EVERY SINGLE TOP END GAMING MOUSE FROM EVERY...
This hailea is just a 'chiller', normally used with aquariums (commonly, reef aquariums generate more heat and overheat because the lighting is...
I never said that (because 'it' was developed for PC makes it a better game). Let me be clearer... I should have said 'crappy' console ports....
+1 more vote for Killing Floor to be added to the list. It may not be the best or latest in graphics (Plants vs. Zombies isnt either... so...
How about Battlefield 1943? (BF3 is in development, but 1943 should be out in the next quarter or so). And what ever happened to Starcraft 2?
Lets see.... Lian Li PC B10, B25, and TYR500 all come to mind...
I do acrylic fabbing... usually do aquariums and reef aquarium equipment... bonding with weld-on, heat bending/forming (cones, domes, etc)....
Have you ever tried fusing polycarbonate before? Pain in the butt. There are problems with a laser cutter though. I prefer my CNC router. A...
Its not acetone, but close. IPS Weld-On, the stuff you use to bond acrylic (usually #4, #3, or #16) is the best. If you are in a bind, and want...
One thing of importance: much of the 'cast' acrylic in the US isnt cell cast. Its something called 'continuous cast'. Its poured like cell...
This article has a bunch of problems with it. I dont use acrylic for computer mods, but I have years of experience with acrylic for reef...
Dont worry, I was talking with someone at nVidia yesterday, and the G100 is the chip we have all been hoping the 9xxx series would be.
Check out that link, the other ones are well under $600. If I had to do it again, I would have gotten the one w/o headrest for myself... I dont...
[img] Ergohuman Collection http://www.officechairs.com/Browse/Mesh-Office-Chairs/Black-Ergonomic-Mesh-Chair-with-Headrest-CH02907.aspx Best...
Ask Lian Li to build a stacker style PC-V 2000/2100 case (5.25" bays top to bottom), with removable plates (400mm x 160mm) on the top and bottom...
