No heatpipe on the board or did you already remove it?
mATX-Boards will fit, ATX-Boards will not. I am also looking forward to see you fitting a CDROM, i always had my problems with that when modding...
What about the clearance between rad and mobo-tray? Will it still fit? I had problems, when i put a 120mm-fan on top of my V1000.
I have got the same case, the same ideas, the same RAM, same board. This is frightening. :worried: I am happy to say that now i am using a...
I must say this is beautiful. The setup reminds me of something i have done before... :rock: [IMG]
"Search this Thread" might be helpful... :search:
No pics for me. :waah:
I must agree to firehed, this look too plain and naked, probably somewhat "unfinished". Maybe some etching would improve the look.
It is this one.
Yeah, Logitech MX1000 and Dell USB Spacesaver Keyboard. That combo roXX. I got the same setup, except a 24" LCD from Dell. Also i am waiting...
How do you keep it running without any ram?
<german mode> also dein Satzbau im obigen Post ist ja mal mies, da muss ich ja 3x lesen bevor ich was verstehe </german mode> I would choose...
Well, fans finally arrived. Got some aluminium fans with led-lights instead of the plastic ones for free, because the ordered fans were out of...
Yes, intentionally didn´t correct my mistake. :D Waiting for the replacement fan which will be here in a day or two.
Small update, more updates this evening (CET): Plexi-Cover for the hole in the middle-section: [IMG] klick for big
I alway use M4 bolts, they fit with no need to do something. :yawn:
Small update, added the edge protection: (klick for big) [IMG] [IMG] Next: side-panel window
Well, there is really no need for the fan grill on the cpu-fan, but i think it looks a better than the plain fan. Tomorrow i will shoot some...
The HSF is a Thermalright XP-120 cooling a A64 3400+. You might be right that the rear fan grill looks better, but i like the look of the top...
Update !!!! Some new hardware but still a "before" shot: [IMG] A tight fit with the Zalman NB-Cooler and the PoV GF6800: [IMG]...
