Merry Christmas Guys! See you in BF3 / SWTOR
Hmm.. if Germany was involved it must the Tank Top!
The Dell is a 750 as well. My components are: i7 2600k 8gb vengeance lp Be Quiet Dark Rock Advanced 128gb m4 2 x 1tb Samsung 1 x blu...
RMA raised and going to take it out the machine tomorrow. I'm not going to try it again and will check the motherboard for any damage. Will my...
Is it possible that other parts of my machine may be damaged now? Is it worth trying again or take it apart? I heard its possible its just a bug...
Well after I tested my rig, moved it to my case and experiencing my new machine for one whole day, my Corsair 750TX started cracking (electric...
No I didn't. it had spread quite well and looked ok
I've just updated my BIOS on a P8Z68-V from 401 to 901 and now seeing temperatures of 24-26.
CPU temperature seems to have resolved itself after updating the BIOS to latest however keep getting CPU Fan error on start up. CPU fan is working...
Well I'm now an expert as I've just had to remove it and re-attach it :duh: Cheers for the heads up. Btw, what temperatures did you see in idle...
Hey Guys, so i've started the build. First off I removed the processor holder from the motherboard. Mistake number 1. Attached it again and then...
Wow thanks for the pictures megadriveguy, I noticed that you left the intel back plate on. I thought the instructions told you to remove it... (I...
How you finding your 600t? I've got mine on its way and am also interested in the fans/cooling/dust info. Have you build it yet, and if so, any...
Thanks all. Indeed I have several cables hidden underneath the motherboard in the box. Rock n Roll! Time to order the rest of the items and I'll...
I guess my question was more specific to the hard drives as my 2 Samsungs arrived yesterday with no cables with it. Would cables be provided with...
Hi All, Over the last few months, I have been gathering the components for my new build. This build is for video editing / gaming so no...
This is the beauty and beast of supply and demand!!
FYI I managed to order 2 Samsung F3 1TB drives from CPC for 43.80 each. http://cpc.farnell.com/jsp/search/productdetail.jsp?sku=CS2008294...
Looks like the price increases have already started to arrive. Should people wait 3-4 weeks for the price flux to pass or is this going to...
I can't comment on which one is best but I have just ordered a ASUS P8Z68 V. I did a bit of homework and thought that the cache that the Z68...
