Wow, I really like this! Only question at this stage, am I right in guessing from the pictures you have single rads in there stacked on top of...
I thought I'd begin to wrap this log up with some decent pictures of the (nearly) finished case. I realise i haven't done anything groundbreaking...
It would seem I didn't get one of the 'good' DS3s :blah: I've tried every setting and every voltage, but can't get over 375 fsb. It's prime...
I'm going up in 5mhz increments, I just didn't think people would really want to see 'Whoo another 5mhz!' so I'm only posting significant progress...
Yep, it's watercooled and at this speed is hitting 32 degrees full load. But I'm always a bit nervous upping the voltage on chips that still feel...
I'm sure this thing is trying to wind me up....apparently if it's a Tuesday the 9 multi works fine at higher fsbs :duh: [IMG] As you can...
You've just hit the nail on the head as far as the problem goes. Worst comes to worst and the mushkin doesn't boot you could always return it and...
It seems to be down to the boards forcing a CAS timing which is too low for the memory to manage, and is something which is supposedly corrected...
Lowering the multi has definitely helped :D [IMG] It's odd really, I do remember now reading somewhere that people were struggling using...
yeah, I know these things are never a sure thing, but it isn't just ES chips that are getting quite a lot higher, between 350 and 400 seems to be...
Hi, This is the system which is nearing completion here Specs are: e6600 Conroe Connect3D X1800XT Gigabyte GA_965P_DS3 2GB Gskill DDR2...
I couldn't help myself, the project isn't quite finished, but I was fed up of waiting to try out this new hardware, so I put the almost finished...
This is looking good already! I guess it certainly helps that you work with materials for a living, I wish I could cut that straight :D
That was in fact exactly what i was thinking of doing, just a small smoked window showing the CPU area of the motherboard :D My PSU isn't sleeved...
We're getting somewhere now, after 36 hours of leak testing (I'm not normally this cautious but I've spent a hideous amount on all these new...
I was thinking the same, very tasty indeed :thumb: doh! replied to the last post on the previous page, but the comment still stands.
It's a 6600. I'm bringing across my watercooling loop from my previous rig with a few adjustments so I haven't really been keeping up to date on...
So I only had it pre-ordered for about six weeks although it seemed like much longer! But it was at last waiting for me on my return from work....
I think that would work well, but I'd have them bigger, a bit like an Australian frilled lizard... [IMG] Now obviously not that big, but it...
I have a TDX which i'll be ordering a brass 775 top for. I'm not sure whether the card will be on water yet or not, but it probably will in the...
