iaudio X5L for 30 gigs of .ogg files and 35 hours of playback
plywood covered by masking tape. the best mouse pad i have ever used.
primary-24 inch benq FP241Wz secondary- 51 inch 80 kilo crt
China? they don't buy games in china, they steal them. Japan? System - Weekly sales (2006 sales) 1. DSL - 135,614 (2,056,107) 2. PSP -...
me crys twin waterfalls on crappy 56k. :waah:
replace your standerd white light bulb with a uv light.
what color and type of lighting are you using? you can put a window on both sides.
i have one that has the same rating and with a 51" crt projetion tv that pushes 220watts , 19" crt moniter, and a computer with 6 hard drives 2...
if you go below a 3500 the venice is a good core. the 3000 is a good deal
what are your temps idle/load
with ati tool you could get ati cards to do it, if that helps you.
nope didn't work, tryed many resolutions and refresh rates. all i got was 720 X 480 at 60 hz.
i have a 51" tv hooked up to my 9600xt with a hdmi to dvi conector. my computer sees the tv and sees the max rez of 1080i but the highest i can...
can sombody explain how the did the tech demos of hdr for half-life 2 before pixal shader 3 and direct X 9c. i beleave it was done on a 9700 pro...
maxor-good price, loud, fast seagate-good life span, quiet WD-shity after 40 gigs
find a old 486 or a tnt2, they should have a heat sink the right size.
it works good on metal but your going to use 4-5 light coats to get good results.
id say the most you need on a hard drive is 10 cfm per drive. so for the 4 you have id get a medium powered 120 cm fan or 2 80 cm. in my rig i...
i wouldn't say md didn't make it big they were not that big in the us but its been more that ten years and they're still selling. in japan they...
if your talking no air flow vs. 50cfm you might have a differnce but anything more probaly won't help you any.
