OMG color pictures in this one...who knows i might not be hopeless ...Thanks
I've searched google and the boards and havent been able to find one...can someone write a "555 timer guide for dummies"? I know this timer...
could you do a quick drawing of the circuit youre using for that?
so...you cant just take two 12v lines and put that to the fan? :wallbash: :duh:
n00b question...i have a fan that runs on 12-24v is there a way that i can get more then 12 volts from the power supply so i can have a high and...
now...tinfoil on electronics? how do i do that safely so i dont short out anything on the LCD?
Yes there is a limit but i dont know what it is...both the calculators i use to figure out the resistance dont let me put in more then 32...so...
i dont know...i'm an idiot...you pose a good problem...i always do mine in parallel so i dont really know...and i think i just read something...
yeah i guess in japan ddr isnt cool any more but the drum arcade game is huge...give it a while and we will probably see it more and more in the US
o...m...g... i wish i knew this kid
well its really up to you what you use...the first one is a parallel circuit...the second one is a series circuit...the difference simplified...
if you use a jig-saw or a saber saw (i'm not totally sure about jig-saw i only use a saber saw because thats what i have) little chunks of what...
Backlighting LCD Ok...so on one of the LCDs i just took off the front plate...after further investigation i noticed that the 'screen' is glass or...
When using LEDs what kind do you suggest? also i dont know where to put them--in front of the window or behind...let us know how it goes
Dunno if you have your LCDs yet but i was wondering if you have had any luck adding a backlight to these particular LCDs
condensation would be what i would ph34r most...dripping water in a computer case is not good...but i think its been done before...so its not...
cant....stop...playing...game...... must...talk...like....this
i dont think anyone does...its a good idea but no one has used it before and undo is just ctrl+z and save is ctrl+s...from using those keys for...
your f-lock is on until you turn it off? mine doesnt do that but thats how it has always been...the number lock doesnt come on when i start the...
reading that makes using my computer feel dirty..... :duh: what am i thinking no it doesnt it just feels sooo good
