Well then I think I'm safe. I'll see if need to speed up the fans manually. Doesn't the card to that itself? PC gaming forever! :rock:
That's a good 10C differential right? My car idles at 7C above ambient, which seems cool enough. Looks good!
I have a CoolerMaster Hyper 212+ for my CPU, everything is sitting inside an HAF 912 Advanced. There's no side fan, one 200mm on top, and one in...
:blah: Just tell me how long this card is going to last me.
Hi, I just got a new rig. It's a 2500k with the 560 Ti Twin Frozr II OC. I just wanted to make sure its not running too hot, here are some...
The spec : 3.3GHz Intel Core i5-2500K MSI P67A-GD53 (B3) OR Asus P8P67 PRO (B3) 4GB 1,600MHz DDR3 Vengence Nvidia 560 Ti Twin Frozr II OC...
If the 650W is cutting it too close, I think I will go for an 850W, maybe more. Later on, if I decide to add another card, I would have enough...
I don't know how demanding the 560 Twin Frozr is, to be on the safer side, should I be getting a better PSU? Also, I'm slowly leaning towards...
I'm really sorry, that totally went over my head! If I want to reuse this power supply, what Mobo should I get? Which Mobo is the one which...
@Deders, Nope, it's this one http://www.seventeam.com.tw/product_contentx.php?theme_select=1english&cid=99&pid=265 Would it be enough for this...
Okay, so the 2600 sounds good. Would it be a good idea to put a cooler on it anyway, even if I don't overclock it, or is it not required?...
I was looking at an i7 2600, but people suggest that the i5 2500k is a better investment. What if I don't want to overclock, which would be a...
I didn't know that. Sorry, I'm a bit of a noob, so if you could just name all the components that would sit well together, and if they provide...
A little over $1000 wont hurt! Minus the monitor and the PSU, I already have those.
Hi, I was looking for some free advice before I went out to assemble my PC. I'm creating a new thread because my problem is unique. I am...
