what is a good readiaor or heater core that can fit inside a shuttle with 2 120mm fans? (1 fan will be mouned on the back)
what is a good 120mm radiator that i could (if possible) fit on the inside of my shuttle, or mount on the back.
http://bestpcmods.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=BPM&Product_Code=SL&Category_Code=GB
i am going to be making a water cooled shuttle it will also be hevely modded. i am thinkig of using the sk83g, would the sn95g5 or sn85g4 be a...
I have seen in zapwizards mods he changes all of the plugs to 7pin or other such plugs rather than the normal ones. I was curiouse as to why to...
