I have WAMP running on my server here, which acts as a downloading station / mp3 & video store. I would like to create a control panel style web...
I have a question about what I said in the title of this post. I have an MO MX4 already, and want to use the 3 pin connectors to control some...
I have a matrix orbital display which I'm using with LCDC.v1.05.29. When my PC first starts up, LCDC loads and displays whatever it normally...
I am looking to start playing around with pneumatic cylinders and valves, perhaps to start building a medium sized robotic arm. I'm having trouble...
The time came, and my trusty laptop screen hinge has worn and busted. floppy is the best way to describe it. a new laptop is in the post (was...
I have my mp3 hard drive on my floor (mistake no. 1) connected via one of those groovy usb>ide convertor things. works fine, all wonderful. that's...
There's only one requirement, it must be able to use molex connectors, or i suppose screw terminals, where i could just chop off the molex...
I'm using XP Pro, on a Tyan Tiger MPX with only one processor installed at the moment, and 512Mb of registered DDR. Since installing XP (or my...
Are there some sort of joiney connector things that would allow one to chain up smaller pieces of cat5 with rj45 connectors on the ends, to each...
You know the sort, you connect it to the atx connector, and when you press the power button on your case, both PSU's start at the same time. I...
[I know the grammar in the title sounds wrong, but rest assured it's "a liquid crystal display" not "an liquid crystal display"] I'm looking...
As you can imagine, when one monitor is at 1600x1200 and the other is at 1024x786 the wallpaper gets a bit screwy. Is there some sort of program i...
has anybody built a carputer? can anybody point me to any links regarding carputers? the primary use for mine will be for using GPS navigation,...
I'm more or less building a type of railgun for my final piece of research for A Level physics. I was wondering if there are any other physics...
I'm after some autoroutesque software (that is, software a bit like ms autoroute) but one that reads out directions as you approach that point. do...
this might be the dumbest thing i've ever (sort of) done. I had some rechargable batteries for my Fuji Finepix 5900 ( think that's the right...
see this post for intro: http://forums.bit-tech.net/showthread.php?s=&threadid=45151 Now the same pc won't boot from the hdd (though it...
I am trying to install Win2k on this machine, though there is something wrong with the CMOS so i cant set it to boot from the cd. This means it...
im after some 80mm fans, and was wondering which are the most quiet / silent ones?
Hey hey, post pics of the smallest ever pc's you've built / seen / bought, just ouf of interest. I'm thinking of playing with one of those...
