Problem sovled :clap:
Cheers for the link ... will give them a try
Same problem here ... colours on Video overlay are totally screwed up using 77.72. They a re WHQL too :) Going back to previous release....
Good review.... gotta check these out.
MMMM now I know how to fit my sensor :) thanks folks..
If you have cleared the Cmos by moving the jumper, waiting a minute or so, then moving it back... if it won't boot, get a new bios chip as...
Got a mail shot from Bulldog... 8M Sounded great. Called them, "sorry only 2meg in your area... you may have 8 meg within a couple of years"...
So there's life in the old dog yet ... Problem is, upgrading a mobo is the cheap part... upgrading a graphics card that £300 is the real prob :)...
Best series yet :) Roll on episode 16 :)
Been using an Exos now for five months. Delighted :) As has already been said, not the cheapest, not the very best, but a Bl**dy good system...
I had the same problem as the thread starter on my AMD3200+ ... it was almost steaming :) Moved to an External Koolance Exos... easy to fit,...
I've found the Koolermaster set works up very well. Yes its 6mm tubing, and I'm not certain what the flow rate is.. but it WORKS. I spent several...
Looks a good bit of kit. I use aKoolance Exos (External Watercooling unit) and was looking at one of these for my 6800GT... Sadly, not yet...
Now you got me..... Please explain... not got my Microsoft Dictionary handy. UTP STP ??? Thanks.
I currently record "freeview" via a normal RF feed taken from the back of my VCR.. that takes a feed from my Freeview box. Quality is "not bad" .....
Completed 6800 Classic units... Not keen to change over.... Its taken me 5 yeasr to where i am now :)
Don't know about attract... it would match the colour of my eyes today :)
Is your power supply up to the job ??? Burning uses a lot of watts !!
Bit of a wild one this. Had the same problem a while back after installing SP2. Without a bios update would not even post.
I lived with the same problem in the UK (only in Summer!) for a coupleof years. Triws many different HS combinations, big fans etc.... Never got...
