Hi, When I came home today my step-sister told me that my pc wouldn't start anymore. She had been browsing the web a bit and then had left it...
Hi again, I made another tutorial. This one's about how to solder tiny SMDs with nothing but a standard soldering iron. Check it out here:...
Hi, I made a tutorial about how to make PCBs with UV light, I thought it might interest you all. Here's the URL:...
Yesterday, I decided to resolder the connections on my VFD since they weren't all that good when I got the LCD (it was done by someone else). I...
I'm been searching on the internet and the forum for 30mins. now and I can't find any good site with decals, logo's, ... that could be used to cut...
I'm ready to paint my case, in fact, everything is standing/laying here before me, so I'm totaly to start, but I've got a question. The spray...
I've wanted to start for a while on my mod now, so now with the vacation comming and the exams almost done, I figured it was time to start. Yes, I...
Can anyone help me figure out what ground pin I have to use on my Abit IT7 for the speaker signal. Here's the pinout: [IMG] It's either...
Ok, I've seen quite a lot or IR receivers here, but they all need some sort of driver, program, etc. A year ago I came acros the site of a...
Can someone measure for me how much current goes through an audio jack. So just measure right channel -> ground & left channel -> ground. They'll...
I was wondering what happens to pin 23/25/39 when the drive is inactive. Are they just 'disconnected' or do they go to high? I need to know...
I was wondering on which sites you can order free samples of IC's, ... I'd like to create a list here, so maybe this thread can be made sticky?
I want to use this circuit to turn off the audio signal to my 5.1 boxes when I insert my headphone in the specified switch. Would this work? I'm...
Has anyone got a simple codelock witch I could use instead of my power-on button (probably using an optocoupler right?). I made this one...
