What i'm doing is upgrading my current motherboard + cpu. And so i'll be making another computer with these parts, my current case is DF-85....
So you'd recommend adding more fans to it? Which fan would you recommend i add and how many/where? I dont want to add too many to make it noisy or...
I'm looking for a case for gaming, i'm getting an I7 overclocked with a cooler and i have a lengthy graphics card, i don't mind how big it is and...
I'm looking for a case to replace my spare pc with. It currently has a 8800gt in it and produces quite a bit of heat, goes to 90 degrees!. The...
Not sure, try contacting them directly sales@cclonline.com
8GB of ram is more than plenty for a gaming system. Games only require around 4gb of ram, the rest is used on the os and background applications...
Usually only get that error on minecraft with an incompatible Graphics card, if you're still experiencing this problem, as i know i'm almost a...
The black screen and all fans spinning up sounds like some kind of hardware issue, as .//TuNdRa said, "Check that your power connectors are seated...
Prince up to and including around £50. I was planning on overclocking my 1055T a little bit perhaps but not too bothered about doing so. I have...
I'm looking for a decent CPU Cooler for my AMD 1055t cpu as the current stock fan gets pretty noisy at full load. Any suggestions? :) Thanks
Hey, the 660TI was released two days ago on the 15th i believe... Anyway, with them, you get a free borderlands 2 coupon. I'm wondering, how long...
As long as you dont run too many programmes in the background or intensive games that require more than 2gb, you're fine :)
The free next day delivery is only for the cclonline website, that i know of.
I'm wanting a triple monitor set-up as i'm getting the new gtx 680 that supports three monitors. I'm having a hard time finding a monitor with a...
