Hi guys, this is my first project log... but I have been a Bit-Tech member for years. So enough chit-chat already, heres the plans: The idea...
:sigh: Okay... I need to know if this is possible... I have a client with a 37" Plasma TV (Panasonic TH-37PD25UP) and we are trying hook it up to...
:confused: Okay... I need to know if this is possible... I have a client with a 37" Plasma TV (Panasonic TH-37PD25UP) and we are trying hook it up...
You think so huh, that was only mbm5's dll file, running with coolmon, and instead of running Explorer.exe I was using Litestep with a...
2700MHz and simi-stable... Well, it was stable enough to play Doom3 on for about an hour, but then it blue screened. Running some different...
Where'd you get the HD adapters?!?! Okay, I love the Harddrive location, where did you get the nifty adapters to make the drives SATA compliant?...
:idea: Okay, I am going to sell my watercooling setup I have now, and upgrade to the standalone VapoChill setup. Not the whole VapoChill case and...
Thats what Im saying... Might be buying a Prommy setup soon, will be keeping the Swiftech watercooling to cool the NB, GPU, and possibly the...
Added info... Heres the info on my setup, which is only partially on the chart now: MSI K7N2 Delta-ILSR :wallbash: Swiftech Waterblocks...
BIP Rad is at the top of case... Radiator is at the top of case, cut like a blowhole, only pulling cool air in. Fan is a lighted green fan,...
Well... The ambient temp was supposed to be system temp... lol, I ment to have said the ambient system temp's were 41*, and this is because...
Okay.. heres some info for yah Current CPU Temp is 39* C or 102.2* F :rock: Current Ambient Air Temp is 41* C or 105.8* F :eyebrow:...
Uhh, there shouldn't be any problems with flow... I am running Swiftech MCP600 12v pump, with Swiftech Waterblocks on CPU and Northbridge......
Use Plexi and Paint it from the inside... Try using plexi, cut it doen to the same basic shape as the metal frames front, and cut your 5-1/2...
Okay guys... found out I have the dated BIP... is it worth upgrading to the BIX ? Just the single 120mm Black 1/2 setup... I want to lower my...
Just some 411... You said you only ordered 8ft... dont know what case you got or how many things you are planning to cool, I am cooling CPU,...
Im doing the same... I also have a Barton 2800+ running stable at 2400MHz, and plan on selling it. It is an unlocked chip from last years...
Hey guys... PC-Extreme.net is holding its second big LAN party in OKC, called eXtreme LAN, and I usually enter my case into the casemod contest....
Thanks man... I appreaceate the help here... I have done about everything I can think of. Seems to run stable at 2400MHz, but when I try to...
Kinda... Like I said, If I go new mobo... I am going new CPU as well, probably with the AMD Athlon 64 FX 51, but thats if I can save the money...
