I don't see how you can back up this argument. The copyright of books, music nor pictures lapses when they are published (in any format) so why...
So I see Well, further down that article the actual conditions of fair dealing (which is a defence and not a right) are explained. So, I...
Err...not quite. If you don't have the express permission of the copyright holder, it is illegal to view or distribute their material....
Going to have to disagree with you there, on one major point. When you download using a torrent you're not merely downloading the file, you're...
I have a Microtek ScanMaker 9800XL, at £1200 it's expensive but it is very, very good. It's probably only worth buying if you need to scan A3...
Do you leave you front door unlocked too? Afterall, if someone really wants your TV and video that badly a little door isn't going to stop them....
Ahh... didn't think of that.. although it would depend on how generous he wants to be. :) I'm still not sure how uploading to his mates on...
Hmm Get hold of an old 10Mbit hub or switch from ebay, put your housemates network cables into that and then connect that hub/switch to a port on...
It is possible Netstumbler and ministumbler will interface with your GPS device and log the coordinates at which it first contacts an access...
