I need to shave ~0.5 mm-1 mm from a flat piece of aluminium (1 x 4 cm area), what dremel bit should i use and what speed? I've just got one so i'm...
I'm thinking of a small case that will require a sheet of metal (alu or steel, not decided yet, color red in the picture) to sit ~5mm from the...
Can i use a PCI Express X16 Flexi Riser Card (like this) with a powerfull video card like nvidia 260GTX? Does the 16x pci-express riser card...
My PS3 got some scratches on it's cover. :( I was stupid enough to tranport it in a cardboard box with the controller inside, without putting the...
I found a local shop that does cnc cutting, but they need me to do a cad drawing of the panel. I wish to do something like this, from 2mm alu...
I have some AC Ryan anodized aluminum panels, this (1mm thick) and this (2mm thick), that i want to cut them VERY clean, just straight lines,...
Something like this: [IMG] All letters are 1-2 mm in size, so i don't think etching will do it. I have a black anodized aluminum piece, that i...
I've read the article on bit tech, about hdd vu meter, but from what i understood from the article, the 20 leds hdd meter version works with leds...
I need white and red, both transparent and small sizes (max 50cm x 50cm)...It's got to be 5mm thick.
I want something like in the image below, a custom extruded text on a aluminium plate, with my exact dimensions and custom font for the letters....
If you know a good place in US where i can find a switch looking like this one (with or without lights), i would be very gratefull: [IMG] I need...
