Hey guys I've got a piece of frosted perspex 330mm x 170mm for a small project I'm doing, and I want to light it up blue. The reason I chose...
...for some ideas. My dad brung this back from his work, I dunno what it is but I wanna do something to it. First off some pics....
Ok so I'm planning a new mod, and I want to put my own power/reset switches into it, but I've never done it before so I'm just planning it right...
Hey well I have finished my case project that I have been working on for some time now and want to show it off, so I thought why not post here, as...
Anyone knoww what it is in my windows task manager and why it is using up ~90 of the CPU bit??
hi there, which leg do i connect the resistor to on the led? the long or short one? thanks :)
Okay when I've wet sanded whatever I need to sand, and it's wet, do I dry it with a cloth or let it dry by itself? Cause last time I dried it with...
if i put a psu that _might_ not work into a pc and plug everything in and turn it on, if it doesn't work could it damage any of the parts? or will...
hey fellas ive got a bit of a problem with my PSU. in my case i just haave the PSU and two case fans in there at the moment and I went to try it...
Hi there I'm just wondering if I can cut off the molex and then solder a new one on, will it be fine as long as the colours match?? Thanks!
Hi there I'm just wondering if anyone knows where to find a guide or picture that shows you where to put the stand offs in the motherboard for an...
Has anyone painted an inverter for a cathode before, and can share some tips? I know these things can cause some problems, I don't really wanna...
ok so i've cut the main hole into the case to let air in, but how do i go about cutting the screw holes? i have tried many a time previous and 1...
hey anyone know of any guides showing you how to add a switch into a basic led circuit? cheers i tried google, couldn't find anything
hey there i'm currently in the process of sleeving my psu and ive run into a few problems. 1. i'm trying to remove the 4 pin atx plug with a...
hi there i'm just wondering in my psu it has a 80mm fan at the back and a 92mm fan also, would it matter if I didn't have the 92mm fan in there or...
Hey there I recently got a Enermax 420W psu and it has a molex labelled 'Extra' , just wondering what it's for. Is it for like a new end graphics...
hey guys i need your opinions which of these 2 airflow setups would be the best for my case i want to have it as quiet as possible really so i...
well my orange uv fan arrived today and i am trying to put it in place of the fan currently in my psu all was going well until i realised that...
I'm just wondering, where do you put them? I'm thinking about adding a couple of uv led's into my psu so I can make the fans glow, and also maybe...
