Hi all, Is there a similar connector to Dupont, but with 2mm pitch instead of 2.54mm pitch please? I am trying to mod an HP Microserver, but the...
One thing I found is that the printed bracket to hold heatsink down is a bit inconsistent. To solve this issue, I had the bracket laser cut in...
So I "designed" a cover for the NUC in Fusion 360. It really is nothing more than a cover with holes for USB etc. [IMG] It looked pretty bland...
Hey it finally works properly on mobile! :D Personally I'm not liking the serif font though :( Please bring sans back!
Never say never though... I'm researching easy ways to make water blocks! Also I haven't figured out a good way to put/hide an Alphacool DC-LT...
The southbridge? It's fine it's only like 3W TDP and it has a copper sink on it :) The VRMs were hot though, and I have since put small aluminium...
The next step is the "base". The design again is done in Fusion 360. The four main long screws that goes through the skeleton are used to...
The first step to building the case is to make a skeleton. This "frame" supports the PCB and then attaches to the water block mount, as well as...
This project is not dead. I'm still working on it. This below is what I was going to put on it to experiment. It's a full EK kit with a EK...
So things were a bit of a roller coaster for me, and I'm spending too much time on the 3D printer (also building a new one from scratch...), hence...
Likewise, can a 240 rad fit on the bottom? Especially in conjunction with a 240 rad at the front. Thanks.
Here comes a new challenger. This is an Asetek 545LC AIO water cooler with a 92mm radiator. This was my original BIG IDEA(tm) when I first got...
Okay so the neoprene idea didn't work last time, and this time I'm trying a different material... And I'm not sure why didn't I think of it in the...
This my attempt of experiments on cooling a very hot NUC, and then build a custom enclosure for it afterwards with whatever cooling method I end...
The smallest mass-produced mATX case that I know of other than the RM2 is the Silverstone SG09/SG10 at 23 litres. Or if you are a bit adventurous...
Many thanks. I've searched Ebay, Amazon, Alibaba, Aliexpress, and TaoBao already. And I don't see anything suitable. BUT! I've found that I can...
Ah crap sorry I should have mentioned --- in the UK. But yea I've looking on Ebay but I haven't been able to find anything. The closest is large...
Hi all, Does anyone know where can I get a mesh sheet that is similar to the following images? (Don't need the indents) [img] [img]...
Hi all, Basically I am using a PicoPSU with a Dell AC adaptor in the HTPC, so it leaves a big hole where a PSU would usually go. Normally this...
