Individuals can choose to break the law if people choose to do it is a revolution/coup, If Rosa Parks had tried that in RSA when I was there the...
The race card never worked on me I grew up across Africa/Asia/Europe and learn't that 'people' are the same regardless of colour, shame I didn't...
Its difficult to make a choice when you have been indocrinated for years to a particular point of view, The alcoholic might be able to leave...
Very very few people can choose not to be, from those who attack a paediatricians house thinking it was a paedophile to those under the influence...
The punishment doesn't seem to fit the crime does it
Sadly thats not true. indocrination and propoganda have a large and proven affect on how people think and act. I'm old enough to remember "no...
The comments on the bill are accurate, Even the US ambasador in the UK stated it would apply to US citizens
Smoking also stops the mind wandering and keeps me awake (although if I need to keep awake I'll stop and nap) I do disagree with the seatbelt...
To allow the state to raise revenue in fines, If it was on safty grounds 3 point would be banned as they cause more injuries than they prevent...
did you run ccleaner after the uninstall?
You will need a codec only if they aren't included in VLC and most are. I use the Klite Codec Pack to fill in the gaps. Do not download individual...
cheers but no joy, It won't boot any of the 3 machines I have available whilst the usb2 works perfectly
As you have nothing to hide when can I install CCTV inside your house and perhaps you would like to provide all your logins passwords and bank...
Hi, I'm having problems getting he supertalent express duo 8gb to boot, I've tried the microsoft tool and manually creating the partition and...
Unfortunately the flats aren't next to each other and he won't let me install dd-wrt (although my understanding is the free version doesn't...
A little help please folks, Ive been asked to connect two flats together by a friend however the total budget is £0 so I need to use the kit...
And thats my problem, that blurring is unacceptable to me, The Benq can't even cope with some movie scenes! I find it very annoying and after an...
My understanding is that it would lag worse than either the dell or the Benq?
Not that I can find. I'm looking for .23 pixel pitch or lower, native resolution at least 2300x1440, IT must colour match at least as well as the...
