You can use app paswords for gmail and use old outlook.
How old is the hardware? Had similar problem with old PSU, it would reboot randomly withing a month from last reboot, sometimes it would last...
Manufacturers will usually have disclaimers such as "hi output is measured in total of runtime including output at reduced levels ...", never...
Missed this then it was revelant, but still I somewhat doubt those specs, to get 1000+ lumens out of XHP35 LED, you'd need to be pushing ~10W into...
honestly havent really worked with asus stuff, so can only guess how hard/easy its to do anything on them. Running pfsense as VM is not that hard,...
Is your switch managed? Iot devices use wifi or something else? If iots use wifi, do they only need to access internet or talk to each other or...
Are they really? Very few optics (except tiktok battalion), looks like next to nothing in night or thermal vision, unencrypted radios, probably...
Its a diode (might be a zenner, but i doubt it), if its placed in parallel with relay coil then its used as a flyback diode. Most likely the...
Didn't change car battery then it started showing signs of old age last winter, payed almost 10x to fix all the carnage now (it leaked and...
try adding uid=<user id>,gid=<user group id> to ftab connenct string. For linux to linux share you might be better of setting NFS, but that is...
For static charge to be generated there needs to be some sort of solid medium (dust in vacuum/duster case), Duster cans in general dont contain...
Probably rely on operator to be grounded, there no way to dissipate static charge wirelessly.
Still waiting for something similar to OdroidW (just add battery/RTC to zero or any other variant ffs). And I'm guessing this wont be sold on...
It has an option for USB or WIFI remote control/logging, there is an "official" apps for PC/Mobile, FOSS FW (opendps) and multiple gui/cmd tools....
This one might be adequate for your needs, but is quite limited as bench PSU - 3V min vout, 50ma steps for current limit, questionable CC below...
Release dates for dune are weird, half of EU and some asian countries got it last week, middle east is getting it on 23rd and rest of the wold in...
Dune 2020/2021 - 9/10. First film in 10 years that made me go to the cinema. As a film its top notch - the score, cinematography, fx, art...
Check GPU vRAM usage, for me thats the most prevalent reason for game/app crash (usually without any error). As someone who hasn't reinstalled...
Now I have an urge to install windows 1 and upgrade it to w11. As long as M$ leaves the option to undo all the GUI "improvements" they can...
All mine were bought from local retailers and the failures were on multiple PC's, so "USB port thats putting out to much voltage" is very...
