https://mariushosting.com/ Check out his guys blog out, interesting read
Random splurge will fill in the blanks a little more. Off the shelf vs own box: Unraid is nice but it is different in the way it works and can...
Must resist urge to buy this....
I have had 3 x 5TB Seagate SMR drives in a synology box and in an unraid box for a few years without any issue. Write speeds to tail off, but I...
Sorry work imploded
On the final hurdle and flashing the latest bios as we speak. I just downloaded every possible revision. 10 Flash highest revision that would...
It was 0901, just done the one hop to 1003. Will try moving up again and see what happens
If the board doesnt bork but instead doesnt flash high enough to support the 5700G then I dont know how I would feel selling it on, would hate for...
I can take a look at USB 2, however I have had the issue in three places: 1) When the bios updater downloads the file itself 2) When I have...
Trying to be frugal as much as possible. I got the board very cheap way back when and in all other ways it suits my needs. ITX is the only hard...
Of sorts, more that I dont want to take my main rig down, whilst I have others its just a PITA to get it setup again in the same way
So my main rig is the one in my signature below. I bought a 5700G CPU to upgrade my 2600 over the break and an NR200 to move everything over to....
CM NR200 ? Ive got one here, havent managed to put it all together just yet..... As for the board, I think I would say B550 > X470, or if you...
1) Does the drive itself come with a checking tool? Might be worth starting there 2) Maybe a reinstall first and see how that fairs before trying...
My cousin (who was over on sat) just let me know he tested +ve on a lat flow this morning and has symptoms. He is doing a PCR today. My lat flow...
Ok being an idiot: [ATTACH] So it will either be a case it will work with both or wont. Doesnt list 3rd Gen.
Hey Guys, On the off chance someone might know. I have the above board and am planning an upgrade to a 5700G Now previously APU (2 series) the...
Second day of feeling crappy for me. To be fair, im a little fragile and colds / flu usually knock me for 6!
Just got my 3rd booster yesterday at the local chemist, which oddly was moderna, non of my friends were given this. Headache, arm ache and the...
You can even run ESXi on a NUC. Just be careful of the NIC they have in them as Drivers might not be in the install image and they are faff....
