Reminds me of the scene at the start of The Running Man.
Ah yes, that link is perfect for finding what I'm after. The caps I currently have are either Cherry or OEM which are too tall and not enough...
Right. I've just got the tape measure out and the surface area of the caps I'm used to are 13mm, and the k95 caps are actually the same size. The...
Those are the ones I already have installed. I'm looking for ones with a larger surface area for my fingers if you know what I mean, the top of...
Hi all, I've been given a k95 keyboard today and as good as it is, the keys are a little small for my liking. Can anyone recommend some...
It's a bit early to start blaming antivaxxers when polio has only been found in sewage up to now. Not a single cae has been reported in humans...
Try minitool partition wizard (assuming you're on windows) It's a simple "right click and delete all partitions" to completely reset the drive....
Same. 11 all the way for me. 11 is just 10 with a new UI, but I've got so used to it I can't go back to 10 because it just feels kind of,...
The Fly?
Getting a Jeff Goldblum vibe from that, Earth Girls Are Easy?
Edit: crap joke.
Hmm, getting a feeling of "get hard" with Will Ferral, but it's not that is it?
You got it.
I think it's time for a much easier clue. Somebody must know it from this still. [IMG]
Ok next clue. [IMG]
Guess again.
Ok no worries, I'll just go again. Here is another favourite of mine. [IMG]
You got it. It took me by surprize when I first watched it too, it's one of those movies that you shouldn't miss out on. Great acting, props,...
I'm afraid not fellas, I'll give it a few more hours before I post another.
Ok [img]
