Nice, someone whos bought one! I suppose I have some questions for you since I've been on the fence about getting one of those controllers. I...
Not understanding this: I thought it was commonly acknowledged that TN panels were among the worst in terms of color reproduction.
Tried it. Been using a c64 monitor, my 2005FPW set in svideo or composite mode, the LCD I hacked up (originally why I wanted it to work). Never...
I have a Sapphire x1900xtx 512MB dual-DVI. I had a MSI x1800XL (XT really) 512MB dual-DVI. I use a 2005FPW via DVI. I want to connect a...
Nice work! I noticed you're using a nVidia card, but is your picture stretched? I ask because getting a widescreen resolution over composite...
No, I dont remember the solder points being that spaced apart, will have to check.
I dont think you guys have seen the L628Bs... 3.61337 Orthos 3.741337 SPi 1M
Um... guys, its four and a half years old! This is THG's third video. The video was made before watercooling had really turned away from kits and...
They dont flash. Should be easy to wire up and enjoy.
I was taking apart my backlit keyboard to get a better idea of why the keys are sticking. Nothing to see really so I started putting the mass of...
Saw this about a year ago. The story is that they were to make a full keyboard out of the screens. It was supposed to be out on 7-14-2005 but...
That would explain why IE6 has the same exact aplet.
Assuming you dont use the horrid CCC, go to Display Propertied -> Settings -> Advanced -> Displays. Then turn on the "TV".
What he said! :jawdrop:
It was in the article thread; may still be there.
LOL! MMO = Massively Multiplayer Orgy
If it plugged into the wall, then it wont hookup to a PSU.
Yeah and there arent any 500GB 16MB HDs out there... Mister_Tadis right. Think about it - they can compliment each other. Perpendicular =...
I bought some from Cable Organizer because my usual place didnt have what I wanted in stock. Try: http://www.svc.com/sleeving.html --->...
Simply :jawdrop: :jawdrop: :jawdrop: :jawdrop: Thanks for this invaluable technique. I have yet to try it (need to find the part first),...
