thank for the info going to order the gpu today for saturday
Gigabyte recommends at least a 850w psu so and it uses a 3 x 8 pin i do have the cables for the gpu so its no problem on that front
Hi all My pc spec Case Lian LI Dynamic O 11 xl MSI B550 Unify, Lian li GALAHAD 360, 5900x 32gb CMW32GX4M4D3600C16 RTX 2080 Corsair...
this is from Hexus and a uk prices are alot less click here than 599euro price ex-vat £365.65 for 1800x which would put it at £438.78
I played this at egx and it was great fun to play
the gtx1070 is due for sale on the 17th i would wait but i have order 2 gtx1080 Zotac Amp extreme because of my new display 3440x1440 Asus
i need to buy one of those SLI bridges as i have order 2 Zotac Amp! Extreme GTX 1080 so i will post bench marks vs the old one
Well i have order 2x GTX1080 Zotac Amp Extreme for my new monitor 3440x1440 Asus PG348Q
i have completed the Elusive Target WARNING you cant save, and if you die you can't kill him, only one chance if you fail there no second chance...
i OWNED THIS GAME AND FOUND it very Boring asked for a refund on steam and go it
Well it looks like we will be getting the first Pascal GPU's to ship in volume in July...
I have a solution for you Type in the Search (Services) then Find Windows Update Then click on Stop it will then Stop the downloading until you go...
I own a AX860i PSU and it a great bit of kit I you was build a new pc I would say get it but if not I would stick with what you got for now
well it most likely just in case Battlefront has issues
well yes I have the alpha and its fun you can see where they want to go with the game
I am waiting for Sky lake myself and do a complete overhaul then
Well at the moment I am going to hold fire I am using x2 780ti I normal upgrade to the fastest gpus each generation but I have a feel that in 12...
here a link to tell you more about the gtx970 problem http://hexus.net/tech/news/graphics/79925-nvidia-explains-geforce-gtx-970s-memory-problems/
Here's what you'll need: Minimum System Requirements •Intel CPU Core i5-2500K 3.3GHz •AMD CPU Phenom II X4 940 •Nvidia GPU GeForce GTX...
the displays I have are 2 ASUS PA279Q 2560x1440 great panels
