RULE #1 - Post some actual progress pictures of a build in the first post of a buildlog. THIS SHOULD BE DELETED ASAP. 1 H8 FKN RUL3BR34K3RS
This is a really sick looking build well done!!!
First rule of bit-tech - first post of a buildlog has to contain "WORKPROGRESS".
This looks very promising :)
Good Luck to you my friend :)
Thank you very mich for the nomination :) very honored
updated this to the AM 4 plattform :) ASrock Fatality Gaming pro paired with the Ryzen 1700x @4.1 ghz with a sett of G.Skill trident Z 3200 Mhz...
Very good choice of words :) !!
i kinda did not want to do something that everybody does (like connecting a tubing from my gpu´s to the cpu and from there to the top rad,) so i...
The same goes for the Tubing of the Cpu and gpu (they alll need to be coinnected to the back compartment of the Corsair Air 540 case. So i had...
So now that the cover has been constructed we needed to create a connection for tubing to the other side (this would not be an issue if we would...
No that we know on how the hardware layout is set up we can go forward to planing the cover in the bottom (since the client doesnt use any HDD´s )...
Project Sleight of Hand Hello everyone and welcome to another Buildlog of mine, my name is Jojo Haraldsson and i am a 32 year old casemodder...
And here are the final HD pictures of the fully finished build. If you are interested in seeing the Project Icemodz Vol 2. Head on over to my...
Barrow fittings ,tubing and custom icemodz sleeved cables with combs are installed :) [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG]
lso for this project the customer had some custom acrylic front panel idea that really put the right touch on the build, but not without the matt...
Getting the windows cut out, i kept in mind to hide what i did not want to show, [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG]
Hello everyone, I recently did a Custom build for icemodz,(Custom sleeviing copmany in iceland) Thought i share the progress with you,...
Black Treassure -- be quiet dark base pro 900 I bought these carbon fiber PC cable combs from Mnpctech here,...
Update: Started on the planing of the loop and doing some bends, also tested the newly aquired waterbock for the cpu and seems to be working...
