All, I am working on a voluntary project where I need to store potentially 10,000's of images of varying sizes (there could even be over 100,000...
All, I have just build a new PC using the CM Elite 130 case. I have a couple of questions: What in your opinion the is the best CPU...
I was with all the way to 'acquaintance'.
Thank you for the suggestion. It looks a great router! Does anyone know if I could use my current DG834G as a modem and connect it to this...
Ok, thanks again for the fast replies :)
Thanks Pookie, I appreciate the fast feedback and added suggestion for which device to look at. I was spurred into looking at my router after...
All, NetGear DG834G - Where I live I get approximately 2Mbps speed. - I have also had this modem router for almost 6-7 years. However,...
My Setup and resulting issue I use normal computer speakers for gaming, which are connected via a 3.5mm jack into the motherboard. I also have...
Aww.. don't rain on the parade.
Is this what they call a 'tock' in PC circles? :) Suddenly waiting a little longer feels even more worth it.
Sorry Bindi, what is an Impact?
I'm on the verge of pressing the button to get an Intel mITX and you come out with this today. .. sigh ok, I'll wait a little longer.
18,460 posts in a thread about keyboards, that must be a Bit Tech forum record? Made even more impressed by a person who only had 58 posts;...
All, Thank you for the comments. They are very useful. Now I'm wondering if I should simply get the CoolerMaster 130 to save a little more...
Hello, Has anyone had any experience with the Scythe SCBSK-2100 Big Shuriken 2 Rev.B Low Profile CPU Cooler? If so would you recommend it -...
What did you use as a stand? Also, I have a couple of spare HP EliteDisplay E231 stands, would a dell monitor such as this fit on to one of these?
Does anyone know if a Noctua NH-U12S would fit in a Corsair 250D?
All, Can anyone recommend a headset with mic, for Lync in an open plan office environment? I currently have a basic Logitech H390 USB...
All, Any other suggestions?
Simply this. It's just too big and I'm suprised, given its in the mini category, few others pick up on this.
