Hi I have a new Reserator 2 , the water block for the GPU doesnt fit. This has been explained by Zalman , but in the mean time I want to buy a...
Hi.. I have a 10" LCD screen... Ive stripped the original outer casing to reveal its wiring.. At the moment it uses a AC Adapter (Output...
Hi guys.. Ive just purchased a Blue Acrylic sheet that I want to make into a window for myThermalTake shark , if it means cutting big holes...
Hi. Im making a new mod and I wanted to purchase some Plastic Coloured glass... Wich sort should I buy ? Plexi Glass or Acryl ? or are...
Hi.. Ive modded many of the spare Wavemaster Cooler master front 5 1/4" bay covers.. is their any where I can purchase some more or does any...
Hi.. I ahve purchased a LCD-Display 2x16 (Sharp LM16A21_ LCD but the software that came with it doesnt let me view the System Temps .. Does...
Hi.. Small tip for those of you that dont like the Artic Coolers with the silly top bracket.. Today I decided that the top bracket from the...
Hi.. Ive read a few reviews with regards to the Zalman Reserator I Fan-less Water-Cooling System, although the Reserator is very big I think...
Hi.. My mod you can view from my sig.. Story is , I stripped a set of Medion Speakers down and mounted the PCB , on/off switch and led...
Etching tips.. hi , on my current project I want to change my window for a etched figure (May be from CS S) but Im not much of an Artist but if...
When modding Power Cables in to 4 pin Molex connectors most have 3 wires , Yellow , Black and red... Is it nessesary to have the yellow ....I...
Hi Ho.. Ive tried searching for a Stealth CD Rom Mod Tutorial but I cant find one with pictures or an updated one.. Any one know where I can...
Hi ho.. I have never ever had anything to do with Water Cooling , so Im wondering if some one would be so kind as to draw up a list off all the...
Hi.. Im by far a poor electrician (Self taught to minimum level) and havnt a frigging idea why this set up Im doing isnt working.. So , I...
Ok this is a 2 part question... Ive posted this different from my Project becuase I think it will get more attention here.. Anyways here...
Hi.. Any Electricians in the house.. I have this unwanted cable and I want to remove it, I think the correct thing to do would be to cut the...
Hi.. I live in Germany and tryinig to find UV acryl glass / Perspex is solid..Does any one know where I can get small sheets of the...
Hi.. First off I would like to introduce my self as being a newb to these forums and have been inspired by the work that goes on here. I...
