I hope they can extend this technology to when the NPCs wipe their arse on the toilet, otherwise I literally won't be able to sleep at night...
“We knew early on that, to hit the fidelity we expect for Sq42, we would need to do some R&D on bedsheet deformation. This work is currently...
I need to know if the golden ticket gives me access to the willy wonka planet!
Hi I am looking to get three of these made up....
Anything worth looking at now?
Keeping the loop below 40c that is just for a particular type of tubing? This august bank holiday weekend I finally was able to get a 3 day run...
Not yet I was waiting for the Active Backplate from EKWB to become available for my 3090 Suprim X, which I think might be quite a long wait. If...
Yep TPM in BIOS was turned off and it now passes compatibility check.
Hey Have a Z390 motherboard and looks like it just missed the TPM 2.0 spec. Looks like MSI offer a slot in TPM module upgrade? Anyone used...
This does 12mm-16mm -...
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313&_nkw=Tubing+Reaming+Chamfer+Tool+Pipe+Reamer+Cutter+for+16mm&_sacat=0
Oh dear! https://overclock3d.net/news/gpu_displays/scalping_at_retail_-_the_uk_retailer_that_tried_to_charge_3000_for_an_rtx_3080_ti/1
I was having a lot of problems making tubes seal properly when I was honing my skills on some test pipes and using a leak tester. After much...
Thanks for the recommendations guys. I did just try torchlight but it doesnt have an onscreen co-op LAN play only. :-( Oooh...
Hey all Looking for some recommendations for a good button mashing hack n slash with an easy character progression/upgrade system. That I can...
Got mine enabled and cyberpunk seems to have a few more FPS. Assuming 3DMark is listed as supported will give it a few runs this evening. Msi...
My Aqua-Computer Flow sensor high flow NEXT just arrived (thanks highflow.nl!) Anyone else using one of these and have any tips for pre/post...
Thanks for the tips @Yaka, I've been watching the video series and its really great. Not sure I will be able to grow a moustache like that though!
Hi All, So I'll be starting my venture into using hard lines for my setup and I was hoping to get some recommendations on all in one tool kits...
No, I have an aw3420dw so its just perched on the desk underneath it. Not a massive problem as only use it when I play with my son but a stand...
