I have driven a car with a seized turbo in it, and it still ran. It definatly didnt run properly that is for sure, but it did run. I would bet I...
Well I guess the first question is what do you mean by "kicking in"? Can you hear the turbo spooling?
Thanks guys, I am not 100% certain, but I am playing around with just writing an XML page and have that boot full screen to launch apps. I will...
Hello, I was wondering if anyone know of a good program to use as a front end for my multi-media box. I would like it to be able to be...
Thank you very much sir. I was thinking perhaps you should post yoru ASCII on deviantart.com. It actually helped alot. =)
Ok, I was wondering if anyone knows how to extract the power cables from the starndard power connector for a floppy drive.
I was just wondering if anyone had a good method for removing female molex pins from the plastic pieces w/o spending 15 bux on a molex pin...
I was wondering if anyone had the link a shop that sold Right Angle Molex Connectors here in the US. Very much appreciated. =) Thanks aot.
I have been a longtime faithful of Maximum PC. I would very much like to see Custom PC here in the US
Very pretty.... Can you make one for my girl...?
Just FYI visible spectrum is from 400 (purple) to 750 (red)... Cheers
Whoever was going to watercool the cat, I woudln't recommend it. I have tried it many a time, and it just turns out with your cat hating you and...
Hmm, wonder why he was banned....
Meh, toxic schmoxic. I used to put it on my toast as well. Not sure if you chaps in the UK have seen the breath freshening strips (thin...
Now why would you go and unplug it? I love staring at a live feed of darkness, its inetersting what your mind makes you think you see. =)
Ghetto mods, does this count? in which case.... [IMG] [IMG] [IMG] [IMG] This was my friends honda, I am the photographer,...
I want the pleasure now! *cry*
Macro needs to get into that contest... FYI, still getting invalid stream, so I missing out. =\
Best spreader around, no need for tools, and no body oils... I have always used my tongue.
