Cheap from my local Lidil... San Miguel
Hello. Merry Christmas and all that. I'm looking for a 40w fanless PSU, for a nettop computer. I've had no luck in finding one. But Im...
So nothing I can do >_<
Hi, I just installed 2142 and updated to the newest patch 1.50. Now i've had this before but just got over it. but everytime I go onto a Titan...
Oh that will be a good read thank you. I was thinking about it and was wondering if there is soe sort of cable/card where I might be able to plug...
I would like to create a media PC, but one of the requirements is that the TV or Sky is on at the same time as the PC. Is it possible to route...
Yeah I think I shall give the AC'97 a go, they are probaly more uptodate that want i'm useing atm ^_^ Thanks for all good help peoples.
I just reinstalled Windows XP Home 32bit, on an nForce4 motherboard with built in sound. I went onto the nvidea site to get the chipset drivers...
ah good glad I could help ^_^ nyahah
I got an Exam tomorrow Network & Operating System Principles & Administration, Then I got my VB on wednesday then Databse Development on friday...
or you could give imgBurn a go. Install then and then double click on the ISO file of W7 and follow on screen instructions. HTH -Pete
To make your own layout you'll need to leanr HTML and CSS, and to make some mods you might need to understand some PHP. SMF is a nice board, I...
I take it your useing Windows Vista? Personal I don't have Vista, so I might not be able to help much, but try changing, if you can, the owner of...
yeah he just did a normal format, and installed Windows XP Pro 32bit. During the install it BSoD many times and said that it couldent find/copy...
Hmm gparted would do the Job, we'll give that ago Thanks
Yeah we have downlaoded the drivers and cheked that they work, MD5 okay. We have even installed them on another computer. The main problem that...
Hi My friend has a computer Sckt939 3800 dual core and a new, well from ebay, Abit AN8 SLI Fatal1ty motherboard, XFX GeForce 7600GT, and about...
