Its the age old battle of the sexes, who is the better driver? well this should once and for all settle the arguement linky so get driving, and...
well as the title says my driving test is tomorrow. Only problem is I think im going to fail, im guessing its only nerves but i cant stop...
Im hoping a 1.1 tbird runs runs cooler then a 2000+ tbred as the cooler i ordered is rated for a 2000+, and me thinking tbirds cant possibly...
Im looking for a low profile card that has good proformance for a project i've got planned. anybody got any suggestions as to what card to...
strangely addictive game clicky clicky best time so far is 21 seconds dead
Ok, I bought myself a cdrw about 8 months ago, yes im very far behind, anyways, it burns CDRs perfectly, but it doesnt burn my 12 speed RW media,...
what do you people to do keep the holes in the bottom of your pockets from swallowing all your money, i.e. what your job is. I guess ill start...
http://www.extremeironing.com/modules.php?set_albumName=album19&id=1_78&op=modload&name=Gallery&file=index&include=view_photo.php Now Thats...
Question, whats the difference between the dfi lanparty nforce2 rev 'A' and the rev 'A+' :confused: i.e. will a rev 'A+' work on a rev 'A' board.
I was wondering if there are any programs available that can rate overclocked cpus against the xp rating system to see where they stand against...
has anyone got any info on the MAtrox MGA power graphics is-storm r2 looks like this [IMG] anything would be helpful, but im...
ive been thinking about getting a new cpu to replace my over worked 2000xp currently at 200x8.5 at stock voltage :D I am wanting a 2500xp but...
I resently acquired an 18 inch tft monitor and was thinking of modding it into the side panel of my case, I know that its been done with psone...
has anyboy ever seen an m-series? bout the smallest computer ive ever seen, once second to my gameboy and my calculator. as ive managed to get my...
currently i have a volcano 9 cpu coolerand was thinking of upgrading to a new cooler, ive come up with two options i like the look of 1. aerocool...
has anyone heard of any liquid nitrogen cooling systems? i know that it would work better then water cooling and is less likely to kill your comp...
ok, heres the problem: one of my mates reacently fried his shiny new mobo and the shop that he purchaded it from now no longer stock it and he...
i was sitting school and i started wondering if it was possible to make/buy a connecter that allows internal IDE drive to be located externally of...
evenin everybody, was just wondering if its possible to have a uv led instead of the red one in an optical mouse? also can having to many uv...
