Usually with most laptops the top half including the screen can be seperated by un doing the bolts/screws holding it as well as its connector....
Greetings and salutations, Last week i picked up the new PP03 silverstone short cabling set [IMG] for my ST60F 600W modular PSU. [IMG]...
I'm going to agree with tkdwarrior, i think a brushed finish would look better with the metallic finish of your sample colors rather than chrome.
The plan looks good, i think your onto a good idea with the 2 lcds, if just so you have the browser list or perhaps a visualisation going while...
Looks good assembled. :)
Ok now i understand the problem a bit better. So here is my revised suggestion [IMG] Drill a hole that lines up on the red holes on both the...
Small update today just a couple more photos. WIth the sidepanels now attached. [IMG] As its pretty obvious from this photo i still need to...
What i meant by it was this [IMG] Using this you only have to undo 2 screws to release the drive and more to the point they're relatively...
Lol thats the same problem i'm having my new motherboard doesnt have a parallel port and the lcd i made up is parallel port wired.
I'm guessing your an aussie based on your quoting "Aus$95" for the checker plate. If your looking for meshx panels of the AC ryan variety i'll...
MY GOD THATS A HUGE ah stacker or 2. Looks impressive so far. I think your right about having mesh at the front to tie in the with the front...
Nice work so far. The edging on the fan grills at the back i think needs a bit more attention and a hand file will take care of that stuff just...
Looks like its going to be pretty solid with that checker plate. So are you going to be painting the checkerplate orange as per the design...
Mr_SCSI i feel your pain over the rear conversion to 92mm fans. I actually got to prototyping a replacement plate but found i kept running into...
Nicely done, that detail is impressive.
Nice lcd, are you just running it from a parallel port or is it serial or usb i didn't see a cable in the pic to indicate? Also PPG are a big...
Hardware Installation I started off putting back in the rear fan mounts [IMG] Looking quite better than the OEM purple. Next up was the...
Installation day cometh. So yes its time to install the hardware, but first i needed to cable wrap the fans and some of the other miscillaneous...
Jeez those look more like personal weapons than spacers for mounting tubing. Awesome work once again.
Nice work so far, i like the detail in the design, however on the same train of thought as Gaoske. Is there enough gap between the rails so that...
