Looking at the front panel, I see all the other red acrylic panels have 4 bolts each. I'd stick with that if it the unbolted holes in the plate...
Another thought occured to me. I got the impression you are at a design school or something similar. If you are around other artistic students,...
Yes....that's the sort of thing I was thinking of. I think you'll need something a little more full of lines though to balance the dark plexi....
I like the look of the Shoji paper/wood combo but I don't think the white paper works well with the dark plexi of the front and back. What about...
I'd like to strongly suggest that those of you debating the merits of G69T's case go make a thread in a different forum and stop cluttering up...
Firehead, you could get some tack paper like the stuff used to line drawers to replace the protective film.
Wow....I just happen to be looking at the thread while you are updating. I just realized that you haven't even gotten to the "computer" part of...
I'm thinking that is the new design for Wolverine's claws for X3. :D
That would be a cool addition to your site. I can see where you might want to maintain the "mystique" of only showing the awesome results of many...
You'd have to be doing it intraveinously to get it that high. Probably have to extract some blood just to make room in your system or your blood...
I think modsquad will agree, prep and patience are key to getting a really good paint job. Taking the time to do it right always shows through in...
Seperators to relieve possible strain. That sort of forethought and attention to detail is what put your work a step above. It is inspiring to...
It'll be interesting to see how that bottle cap gets incorporated into the mod. :P Great work you're doing.
This is coming along nicely. If I may make a suggestion, countersink those screws a little further and cover them with wood plugs. I'd hate to...
Have you tried steaming the wood veneer to get the compound curves on the mouse? It's just an idea off the top of my head but it seems like it...
This is looking to be a sharp mod. I like working with wood too and this will be the first mod I've followed that is made of real wood (as...
I just came across your project a few days ago and have been reading through it. I'm finding your workmanship and attention to detail excellent...
Another idea: Do some painting around the dragon, like an aurora of energy or flame, and polish the rest of the case like you want to. It'll...
