I would be more than happy if current cards just had a die shrink. lower power less heat.
ILL go along with the $250 price. $275-$300 for soo the called high end models. I dought there will be much over clocking head room as its the...
the gtx 460 is a great folding card but is no longer watt,cost,ppd leader the 450 is
In the Folding rig. you stat, system is for maximum ppd per pound per watt. for close to the same money you can build a i7-970 rig. make way...
i want the gf104 with all of its shaders.
This new form factor if it doesnt add 10%-20% more cpu power its a complete waste.
your folding rig isnt the best ppd/watt or ppd/$ with smp bigadv i7-860 running 3.8-4.0 275 watts. ppd will vary 21,000ppd on a 2684,...
putting in 4 gpu's for folding in a 24 threat rig is a waste. those gpu's are stealing enough cpu time to kill most of the points they gain.
Would like to know the folding performance?
here the memory i use http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365...
Mine wouldnt new card new drivers. though i didnt buy it to fold just needed a cheap card for my i7 rig
I was just reading some of your threads. thought maybe i could help you guys get a few more ppd folding smp. A3 core like high bus speeds....
try restarting the client sometimes that works for me.
i didnt think any 8400gs would fold?
I did a 6041 in about 16 hours 10,000 points from what i remember
upgrade tp 6.29
Depending on your power supply. the bfg gtx 260oc come with 1 molex to pci adaptor.
you should be able to hit 4.0 @ around 1.35 vcore does your case move a lot of air? depending on how much gaming you do bigadv is easyer to setup...
All three of these cpu's will do 4ghz with a good cooler and Motherboard. if your gaming and folding stay with the I7 and nvidia. Im not a gamer....
I would love to see some smp folding screen shots running 4.7 using hfm.net 30K+ a day?
