bogie170 - Control Panel, Mouse, Pointers tab - change away! Or else, open Control Panel, enter 'cursor' into the search box, click the link to...
Looks good - strictly, sidelights should be green, not blue, and I think the same applies to auxiliary lights (the only one supposed to be blue is...
Just spent the last 2 or 3 hours reading this - simply epic, brilliant attention to detail, and it sounds amazing with no exhaust - hopefully the...
So, if I execute a piece of code and give it admin rights, it can reboot my PC. Wow. A batch file containing 'shutdown -r -t 0' would do exactly...
Maybe if you did live in London you'd realise he's actually doing a pretty good job so far, an awful lot better than Red Ken...
LOL forget that - the top-level child <div> was set to position:absolute, which evidently screwed the whole thing up and was completely...
Hi all, It's been a while since I did any web programming, so I may have missed something obvious here, but I just can't spot it! Take a...
OK, let's try something different. Open up Device Manager, Network Adapters and delete (remove) all network adapters. Shut down the machine,...
OK, that's fine - in Network and Sharing Center, click the link on the left to 'Manage Network Connections...'. What status does Local Area...
The lack of the packet scheduler miniport device is to be expected - Vista's networking stack doesn't work in the same way, so it doesn't require...
Well, I went from this page - the link I provided is clearly to the INF installer on Intel's download mirror site, but point taken.
Quack's spot on - if you look closely, all current XP updates are labelled 'sp4', and it doesn't look like MS are even planning on releasing one...
One moment, sounds like he means foam on the inside of the retainer that goes on the back of the motherboard - this should be left where it is, as...
Sounds like you've tried a bunch of things there you didn't need to. First-off, I wouldn't bother disabling TCP/IP v6. The Vista TCP/IP stack is...
3.5u2 has some nice added server hardware monitoring features - it can read things like temperatures and voltages from BMC sensors, and also get...
Affected 2 of our servers, though fortunately they were only running test machines, not production systems. Rumour has it they left in a time-bomb...
Bear in mind this daft MiB/GiB/TiB labelling system has only existed since 1998. Hard drive manufacturers are the only ones who still use the...
In what way is Vista x64 'AWOL'? I've been running the 'gold' retail code here for a couple of months now with no issues to speak of...
LOL now where are the people saying they'll use Vista when they can make it look like 3.1, or DOS? Bet you won't use Office 2007 until you can...
All editions have 'full DX10', I'm really confused here, what do you think the lesser editions don't have?
