managed to get this sorted. Picked up a BT modem off ebay, worked out which port did what as port 1 was the bridged port. picked up a TP link...
thanks guys. picked up a BT open reach modem to try. Should be able to test it at the weekend.
hi all, I've recently moved house and have to "downgrade" to standard internet via talktalk. I'm looking for a half decent / cheap vdsl2...
so after some further investigation and a fluke i believe i've found the issue :( The keyboard itself is a corsair RGB keyboard and with it...
i use to have a K800 but it lost a few keys so i replaced it with a cabled keyboard. i switched to a gaming keyboard and at the time couldn't...
Computer now sits on the wall further from where it use to. I'd decided to wrap the usb cable round the side of the room to where i sit.
Hi all, Does anyone have any direct experience with USB3 cables over 5M? I brought a 8m active cable which has additional usb power lead which...
just to update. Took the waterblock off and re-seated it. there was sufficient thermal paste covering the block and cpu as well as no protective...
the models don't show up on the old machine. As well i have checked to try and find some drivers for the actual monitors but nothing so far.
hi all, Hopefully someone might be able to shed some light on this issue. we currently have a computer serving 9 monitors over 5 graphics cards....
so the setup is as follows: Pump/res - GPU - CPU - Rad then back to the res When i cleaned the thermal paste of the cpu i did give the CPU...
didn't touch the block apart from mounting it on the board and plumbing it in. there is water flowing through it with no issues from what i can see
sooo, i decided to take the plunge and watercool my current rig. I've finally finished it and after running the pump for a bit it seems to be...
2 years. I've had it replaced now under warranty so not all that bad
well finally got a response back from logitech. They are going to replace it under Warranty which is good. tbh i didn't even think it had any...
not really. but i guess no more than £80 - £100 as thats what the K800 costs. It's more to see if there are actually any alternative ones to...
is there an alternative to the logitech K800? I currently have one but some of the keys have stopped working. I'm speaking to logitech's support...
Hi all, I've got a K800 keyboard and just recently several keys have stopped working. the keys in question aren't in a group but sort of dotted...
Passed my Mod 2 at the end of August, when i came back from holiday i went and brought a Yamaha XJ6 for a good price. been riding it pretty much...
well after much looking at working on something similar i found out the issue. The reg key went into the wrong location :( there is a path similar...
